kmacht wrote:Something to think about, just because the engine mounts are the same on the revmaster/great plains / aerovee, doesn't mean that it will still fit the same engine mount and airframe. Things like the starter, alternator, intake, and exhaust for the aerovee were all designed to fit around a Sonex/Waiex/Xenos mount and cowling. Are you sure that the other companies will fit or are you willing to design a new mount and cowling to make it fit? Will the sonex baffling fit or will you have to design your own? Is the prop hub lenght the same? Lots of variables to think about.
kmacht wrote:Nice. I didn't say it couldn't be done, just that there were more variables to consider than just if it fit the mount. It's good to see that someone has already tried it with the revmaster and doccumented it with pictures. Do you by any chance know of someone with a similar site for the great plains engine?
rizzz wrote:The GP engine also fits on the Sonex VW mount and under the Sonex VW cowl.
radfordc wrote:Note that most of the GPAS engines have a fairly large "bump" on the top of the cowl to clear the ignition system that mounts in the distributor hole on the engine. The Aerovee doesn't have this issue.
