Aeroinjector -- caution!
For several weeks I've been chasing high CHT's. I've moved the oil cooler and it's air intake. I've removed
the baffle under the oil pan and closed off the front hoping to get more pressure difference above and
below the engine. Nothing I did made a difference. In addition I was gradually richening up the needle
position .. or so I thought.
Then I removed the carb to look it over and noticed that whenever I tightened the set screw against
the needle carrier it was also screwing the needle carrier in leaning out the mixture. Because of the
simplicity of the aeroinjector it never occured to me that the needle position could be changing.
Now the scarey part. This morning while I had the carb off and could watch it I reset the needle to
the starting point and while holding the needle so it couldn't move tightened the set screw.
I went flying to test. About 2 miles from the airport my CHTs hit 400, then my EGT's shot up over 1400.
At the same time the plane was losing RPM and wouldn't run at other than full throttle. I managed to make it back to the airport at full throttle position with the declinging RPM. I'm attaching a pic of what I found afterward. The needle carrier had vibrated loose and worked it's way IN in the course of the 5 min or so I had been flying. I made sure the set screw was tight against the carrier screw before I fired it up.
The board won't let me upload the file. I'll try to reduce it later when I get home. But the needle had worked it's way in by about 1/2 inch or more nearly shutting off the fuel completely. Had I not been close to the airport I would have ended up in the swamp.
I won't fly behind an Aeroinjector again. Does anyone have any other carbs they've had good luck with?
RT
RT
