Engine Balance
Recently received my Aerovee Kit. As I was going along I decided to weigh the parts, the connecting rods were very close but then I found one piston 2 grams lighter than the others. This got me wondering if this was very significant. Tech support informed me that 5 grams was the “manufacturers variance standard” and I was well within that and I believe that is absolutely true. But after reading Tom Wilson and R.S. Bob Hoover they seem to see the variance builders should accept and manufactures variance as 2 different things.
Wilson addresses balance issues on page 45 of his book “How To Rebuild Your Volkswagen Air-Cooled Engine,” recommended in the Aerovee instructions booklet, and indicates he accepts no tolerance just says they must weigh the same, I interpret that as an ideal. Hoover in his rather extensive blog on the subject states there should not be a weight variance greater than 0.5 g. As best I can determine balance shops work to 0.01 g. maximum, but normally less and most to 0.0 g. which is really not that difficult, for them.
While the Aerovee is pretty much a rather bulletproof design and will run balanced or not, being balanced would seem, both in weight and volume, a good idea. I have not been able to find any other discussion of this as it relates to the Aerovee and was wondering if anyone can enlighten me on this subject or point me in the right direction?.
P.S., If you haven’t read Wilson’s book, you probably should it is a LOT more detailed in the steps to take in building your engine.
