SonexN76ET wrote:Aldo, a crankshaft failure has never been an issue with Aerovee 2.1's.
Also some other engine builders have tried to make this an issue to try to sell their in house engineered cranks. But research shows these other firms have had their share if crankshaft and prop hub failures………….
There are plenty of uninformed opinions out there on other forums.
Jake
SonexN76ET wrote:Please keep the name calling off this forum.
SonexN76ET wrote:All I am saying is I am not putting out misinformation. Dale, the turbo is 100+ HP. I think someone said in a video it may be close to 110 HP. I consider it name calling when someone says I am putting out disinformation. I will happily leave this forum and just mind my own business if this continues. Let's be civil and respectful of each other!
As far as crankshaft/prop hub failures go, there have been very few in the VW conversion community. What I have seen, however, is that other manufacturers have tried to allude to these failures being primarily to do with the Aerovee and have done so to push their custom crankshafts.
Here is the NTSB report on a Great Planes powered Sonex that had a prop hub failure: N164JL, NTSB report LAX02LA279
It also says Great Planes had to put out a service bulletin due to this one and another one.
Relevant text:
"During a telephone conversation with a National Transportation Safety Board investigator, the pilot
stated that while in the initial climb, about 300 to 400 feet above ground level, the engine surged
and the airplane could not sustain lift. The engine was still producing power, but failed to
distribute that power to the propeller. With a lemon grove directly ahead of him, the pilot opted to
turn back to the runway to land. As he began a left turn toward the runway, the left wing impacted
the dirt and the airplane "cartwheeled." He felt a violent reaction in the cockpit as he was thrown
from the airplane.
The pilot further stated that, while doing an engine teardown, he discovered that the propeller hub
had separated from the crankshaft. The non-aircraft grade bolt that connected the hub to the
crankshaft had "backed out" leaving the propeller spinning freely. He also noted that 2 weeks prior
to the accident he had a similar propeller hub to crankshaft separation problem, at which time he
removed the propeller hub and reattached it. He thought that the bolt's threads were loaded
improperly and the bolt was not sufficient in transferring the load.
The Volkswagen Type 4 engine crankshaft end has a conically tapered end with a shoulder reduction from
the crankshaft diameter that in an automotive application contains a press fit pulley. To adapt the
engine to aircraft application, a conically tapered metal sleeve (the kit manufacturer refers to this
as a "tapered spacer"), which is seated on the shoulder to bring the diameter of the shaft end to a
constant taper for the propeller hub to fit over.
Great Plains Aircraft, a distributor of the Volkswagen Type 4 engine, released a Service Bulletin
after investigating this and a similar accident. Their examinations revealed that the bolt did not
fail; rather, the bolt loosening and backing out is a result of the tapered spacer spinning on the
shaft. They further stated that normally about 51 percent of torque is transmitted through the
tapered spacer to the tapered crankshaft. They noted that if the tapered spacer breaks loose, the
entire load is distributed to the rest of the crankshaft. The length of the tapered spacer is about
1.250 inches, with the remaining length of the crankshaft/propeller hub taper about 1.200 inches."
The AeroVee Turbo is rated as a 100 horsepower engine at sea level, and yields significant performance enhancement to the Sonex line of aircraft without breaking the bank.
Users browsing this forum: No registered users and 107 guests
