AeroVee Oil Pump & Oil Bypass Plate Bolts
PostPosted: Sun Jan 18, 2015 12:56 pm
by SNX1508
Anyone experience this problem.....
The bolts that came with the ACV-P01-55 Maxi Oil Pump do not screw into the crankcase. Bolts are M8 x 1.25, crankcase hole is M8, but the threads in the crankcase do not match the bolt thread pitch.
Same issue with the single M8 bolt for the ACV-P01-11 Oil Bypass Plate, bolt is ACV-Z01-19, M8 x 1.25, but again the threads in the crankcase do not match the bolt thread pitch.
I will email Sonex tomorrow, just hoping someone has seen this before and knows what the correct bolt thread is.
Terry
Sonex 1508
AeroVee 0736
