Setting the deck height
Postby Gripdana » Sat Dec 13, 2014 11:55 pm
I am setting the deck height and compression ratio. Compression ratio is going to be 8:1. When I measure the deck height according the Aerovee manual it ranges from +0.01 to 0.00 (piston below the cylinder). I measured in the center and 4 places around the outside using a straight edge and standing it up against the studs. The measurements are 0.00, +0.005, +0.007, +0.008, the center is +0.01. The chart shows the required shims are the same for 0.00 and +0.01. I guess my question is where do you measure or did I do it right the right way?
Dana Baker
Scratch Built
First Flight March 8, 2015
Gripdana
Re: Setting the deck height
Postby wlarson861 » Sun Dec 14, 2014 12:30 am
The manual shows to measure at the edge, which is how I did mine. make sure the cylinder is seated all the way around. I gently tapped it with the soft mallet to make sure it was seated.
Bill Larson
N861SX
wlarson861
Postby Onex107 » Tue Dec 16, 2014 11:59 am
The piston has considerable clearance in the bore cold. It could be slightly cocked giving you the odd measurements.
Postby Gripdana » Wed Dec 17, 2014 10:36 am
Thanks for the help. I ended up rotating the crank again and re checked the deck height. I had the same results. When I checked the shim chart all the measurements fell within the same range for one .06 shim. 0.00 deck height required one and +0.01 required one.
Dana Baker
Scratch Built
Gripdana
Users browsing this forum: Google [Bot] and 78 guests
