grevaly wrote:I am wondering if your front brearing was not seated on the crankcase dowel pin causing the front of the crank to be out of center and the prop hub
rubbing the front of the case where it has been machined for clearance of the hub and causing the bearing to wear into the crank shaft. When I put my
engine together I had let that bearing pop out of place and on my initial tightening and checking for smooth rotation of the crank noticed the problem and was able to correct it.
It is a good thing you tore that engine down.
Users browsing this forum: Bing [Bot] and 1 guest
