wlarson861 wrote:I'm pretty sure the spring didn't fit inside the plunger but rather pushed on the shoulder of it but frankly it's been a while since I had it apart. Remove any burrs you find on the spring as well as the plunger. I don't recall any problems with the spring, just the plunger.
wlarson861 wrote:You probably need to polish the rough edges on the rear plunger. Mine got stuck and sent the pressure high enough to cause a leak in the oil cooler which lost all the oil and seized the engine and forced an off field landing. On tear down I found the rear oil pressure plunger stuck in the closed position to the point that i had to use a screwdriver to wiggle it free. I used some scotch bright to smooth the plunger until it would not stick in the galley. On the second rebuild (Nicasil cylinders) the plunger fell free when I pulled the plug and spring.
