Oil breather line exit location
Postby Fastcapy » Sat Sep 13, 2014 11:32 pm
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Re: Oil breather line exit location
Postby MichaelFarley56 » Sun Sep 14, 2014 8:36 am
I had a small amount of oil on the belly after every flight and it was bugging me so I added an air/oil separator which cured the issue. I haven't had an issue with it since!
Waiex #0056 - N569KM
Jabiru 3300A #1706
Postby mike.smith » Sun Sep 14, 2014 2:43 pm
Yes. I had my exit in that same location and it sucked the oil right out. I've since moved the outlet to its own hole in the cowl, with a slight forward-facing angle on the outlet, to get a little positive air into the tube, instead of the Coke bottle effect of air over the hole creating negative pressure. Has made a HUGE difference in the amount of oil on the bottom of the plane.
Users browsing this forum: Google Adsense [Bot] and 81 guests
