kmacht wrote:I'm running the stock sensenich that Sonex sells. I was surprised at 3200 rpm static as well but am not going to complain.
Maybe if I describe the issue a little better it will help. The engine advances right up to 3200 rpm with no hesitation or stumbling. The throttle is probably at about 7/8" all the way forward at that point. If I push it forward the last 1/8" that is when it starts to stumble. It still stays right around 3200 rpm but runs rough. If I pull the mixture about 1/3 of the way out it still goes up to 3200 rpm but no longer stumbles when at full throttle. I remember reading somethign along time ago about having a way to keep the slide on the aerocarb go full open and that if it was completely wide open you could get stumbles like I am experiencing but I haven't been able to find a reverence to that again. Is there a way to limit the slide from completely opening up?
It seems like I need to lean the mixture out some more but am concerned about getting too lean and damaging the motor.
The only other issue I am having with the motor is a semi-high oil pressure. It is within limits at around 85 on startup and settles down to around 70 when running but this is alot higher than others have reported. I need to check the pressure with a mechanical gage to make sure what I am seeing is real and not a sender issue.
kmacht wrote: I remember reading somethign along time ago about having a way to keep the slide on the aerocarb go full open and that if it was completely wide open you could get stumbles like I am experiencing but I haven't been able to find a reverence to that again. Is there a way to limit the slide from completely opening up?
kmacht wrote:At full throttle with the mixture leaned the EGT's climb right to about 1400 before setteling out. They drop right back down when I pull the throttle back. The CHTS's are all well within limits staying under 300 degrees.
Users browsing this forum: No registered users and 100 guests
