SvingenB wrote:I must order my engine now, but I'm still a bit confused about the Aerovee and the aerocarb. Has anyone here done aerobatics with this setup? how does it handle maneuvers with several g's, like a loop? What about zero g maneuvers? does it stop? Will it run in a spin?
That's how I see it. People are doing aerobatics with the Aerobcarb and the engine keeps running through the bottom of loops, split-S's and similar high-g maneuvers, so that's good enough for me. If I planned on competitive aerobatics maybe the answer would be different. But the simplicity and weight savings from eliminating the fuel pump and carb heat pay off the other 99% of the time I'll be at, effectively, 1-G. It's another aspect of that "reality check."SvingenB wrote: But as long as it works with some minor fiddling with the mixture lever at "high" g, I guess it will do. A carb from Great Planes will be OK, but then carb heat is needed. A Rotec TBI would also be OK, but then electric pump is needed, two maybe to get some redundancy.
Users browsing this forum: No registered users and 65 guests
