kmacht wrote:What size wire are you using and what type of fuse? The fuse is there to protect the wire not to protect the battery or regulator. If the wire size can handle it you can go to a bigger fuse. There are also different types of fuses. Some are fast blow and will immediately blow if you go over their amp rating. Others are slow blow and will let the amperage go over by a certain percentage for a specific amount of time before blowing. With that being said 25 amps sounds reasonable to me if using a slow blow fuse and the correct wire size. I would check the wire to make sure it isn't chaffing or rubbing somewhere. Also make sure the fuse holder is mounted or held down somehow. Some fuses will trip if they are vibrated or shaken too much.
oynif wrote:I suggest that you check the screws that hold the rotor part of the alternator and the trigger shaft assembly on the flywheel.
No charge and a C/B popping ( 20A with a 10A alternator) were the first signs of the failure of the assembly as shown under the title " alternator or voltage regulator failure ".
If you can detect movement when applying pressure to the trigger magnet it is probably too late.Guess how I know.
Users browsing this forum: No registered users and 45 guests
