Bryan Cotton wrote:I received my AeroVee either September or October of 2014, same date as the other problem children.
Bryan Cotton wrote:Also I did ground the magnetron bodies. I put a lug under one of the mounting screws on each magnetron and ran that wire to my ground block at the starter. Before I did that, it ran poorly on the magnetrons only. After that I was able to get 3000+ RPM static on just the magnetrons.
Rynoth wrote:Bryan, I'm sure you've done this already but figured it's worth mentioning... do you have a dedicated heavy-gauge ground wire from your starter to ground block? Otherwise your starter could be finding its ground path through those magnetron lug wires.
Users browsing this forum: FAST WebCrawler [Crawler] and 43 guests
