AeroVee Performance (Cold Air Induction)
Re: AeroVee Performance (Cold Air Induction)
Postby Bryan Cotton » Tue Feb 27, 2024 12:13 am
Now I just need to plumb some air into there. I'm working on my inlet. Here it is with a hole in the middle and rough cut on the bandsaw:
inlet sawed.png (591.8 KiB) Viewed 1773 times
Poor man's lathe:
inlet mounted in drill press.png (524.79 KiB) Viewed 1773 times
Sanded into a cone:
Inlet sanded.png (598.09 KiB) Viewed 1773 times
Some more tweaking and a quick fitup:
inlet trial fit.png (458.59 KiB) Viewed 1773 times
Postby Bryan Cotton » Sat Mar 02, 2024 6:52 pm
Inlet glassed up:
glassed inlet.png (284.29 KiB) Viewed 1638 times
With the tube in place:
inlet with tube.png (539.77 KiB) Viewed 1638 times
Postby Bryan Cotton » Mon Mar 04, 2024 10:22 pm
I bonded my inlet in place. I laid some plies from the inside of the inlet to the inside of the cowl.
inlet bonded inside view.png (531.33 KiB) Viewed 1481 times
Next I scuffed up the tube, glued it in place, and added some plies to fasten it securely to the cowl.
tube bonding.png (554.58 KiB) Viewed 1481 times
Front view. I propped the cowl up higher and cleaned up the resin so as to not bond the inlet to the work table.
inlet and tube front view.png (481.46 KiB) Viewed 1481 times
Postby BobDz » Mon Mar 04, 2024 11:42 pm
Looks pretty cool!
I see we have very similar lathes.
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Postby Bryan Cotton » Wed Mar 06, 2024 9:46 pm
Ready for test. I'll do the paint and bodywork if it works good.
fresh air induction.png (811.92 KiB) Viewed 1310 times
Postby Weatherpilot » Thu Mar 07, 2024 7:02 am
Bryan -
I'm a bit new to this glass thing. Is that insulation foam you are using for the shape and then glassing over?
Greg.
Greg Hubert
Sonex A #972 TD
Third Owner
Weatherpilot
Postby Bryan Cotton » Thu Mar 07, 2024 8:08 am
Weatherpilot wrote:Bryan -
Greg.
Yes, it's what I had laying around. We actually built the hovercraft out of the same foam but with a thicker sheet.
Postby Bryan Cotton » Thu Mar 07, 2024 10:13 am
Flew 0.6 this morning. On takeoff at full rich the EGT went to 1415F, so I need to tweak the needle rich. It took about 1000' of climb to drop below 1400. It says I am getting more and denser air to the engine, which is a good thing. I didn't really need to lean in the climb until 4000'. I was cruising around at 110kias and it was happy. In a 130kt descent it was happy. It was pretty much happy everywhere. Engine temps were good but it was in the mid-30s. I actually had to turn my cabin heat down a little bit. My oil temperature was about 190F.
Postby Weatherpilot » Fri Mar 08, 2024 2:21 am
Way to go Bryan -
Keeping the"experiment" in experimental aviation...
Greg.
Greg Hubert
Sonex A #972 TD
Third Owner
Weatherpilot
Postby Bryan Cotton » Fri Mar 08, 2024 4:32 pm
Thanks Greg!
A bunch of sanding done, some more to go yet. Will probably fly it again with the tweaked needle position before I complete the aesthetics.
inlet sanding progess.png (556.19 KiB) Viewed 1053 times
