I mounted a little piece of pipe into my exit plenum and secured it for a test flight. The idea is to pull the air out to a separate external exit.
- air goes in here.png (549.41 KiB) Viewed 7793 times
- air comes out here.png (509.95 KiB) Viewed 7793 times
This aluminum tube is sealed to the plenum with metal tape. I used a little shop vac hose for a temporary test.
- hose through bottom of cowl.png (709.7 KiB) Viewed 7793 times
I even used the hose end that plugs into the vac as my exit.
- shop vac pipe.png (511.83 KiB) Viewed 7793 times
Initially it seemed like I had a winner. Temps looked really good during climb. They were slowly going up towards 200, it was 90F out, and I was at full power and 80kts. Leveled off and after a bit it seemed the rate of increase was going up even though I was at cruise power and 100kts. So I landed, and found the hose had softened, rested on the exhaust pipe, melted and sealed itself.
Based on my initial positive results I am pursuing this further. The shop vac hose, besides not handling the temperature, is only about 1" ID and corrugated. It was too long also. So I've got some 1.75" scat tubing on the way. I plan to do this right and try again.
Why am I messing with this approach? My CHTs are almost always under 300F. I don't want to screw that up. The only time I went over 400 was a month ago, doing patterns in the heat. The oil got hot first.
