XenosN42 wrote:Hi Peter,
It appears that you've misread the graph showing my cylinder head temperatures. The lowest is the cylinder #2. Your #2 cylinder is also the coolest. Here is a larger image of the graph.
When I look at the graphs from my flights (and I do save the data my EFIS stores from every flight) I'm more concerned with changes than absolute numbers. The raw numbers could be due to installation errors, a slightly bad CHT cable, errors in the EFIS, etc.
Now let's say that the temperature line for the #2 cylinder starts to match the other cylinders. One might say "it's still well below the maximum allowed CHT so no problem". However, the change indicates that something may be wrong and that should be investigated.
Regarding your high CHT on climb out you may want to consider testing to see if the temperature of #3 is really as high as your instrument is measuring. Harbour Freight has some inexpensive infrared thermometers that will suffice. Just fly around awhile, land, quickly take off the cowling and see if your EFIS numbers match the thermometer.
Also make sure that your mixture is rich enough during climb. Lean engines run hotter.
Good luck. At least you didn't experience what one local builder(?) and pilot(?) did on his first and only flight. ( Don't worry he walked away, but his Sonex didn't fair so well. ) Turns out that soon after take off at about 500 feet his cylinder temps were hitting 500. He quickly completed the pattern and managed to stall about 50 feet above the ground. After the first bounce the plane wing landed on a runway light which cleanly cut thru the bottom and top skins.
So why were his temps so high? A few days before that flight I was showing a few local pilots this guys Sonex, and comparing it to my XENOS. When I looked at his AeroVee I noticed that the super tin was installed on the TOP of the cylinders. So I asked him "Is this installed correctly?" He said "I think so". I pulled out my manual and pointed out the page that describes how to install the super tin. I then said "It will only take you about 2-3 hours to install it correctly. Not much time considering you spent 10 years building the plane. But if you don't do that at least take it off. It's doing more harm than good on the top".
Well guess who decided not to invest that 2-3 hours?
-- Michael
XenosN42 wrote:....When I looked at his AeroVee I noticed that the super tin was installed on the TOP of the cylinders. So I asked him "Is this installed correctly?" He said "I think so". I pulled out my manual and pointed out the page that describes how to install the super tin....
Users browsing this forum: No registered users and 110 guests
