Area 51% wrote:Try this.....You don't need to have the crank installed in the case to set the end play. It's easier to assemble the crank, bearing, shims, and flywheel on the bench and check the clearance with a feeler gauge there.
Did you remove the temper in the pushrod by heating it up to install the ends?
