radfordc wrote:Joe, I think there is something else to be said for the top mounted cooler. Without the air flow into the bottom of the cowl you should get better engine cooling due to higher pressure differential. Did you notice anything like this?
gammaxy wrote:I have a top mounted cooler and have been working on the cowl. I believe the plans still say to cut the "mouth" in the cowl even if you have the top cooler, but had been considering leaving it off. Without the mouth, does it still use the fiberglass flap and southco fastener to securely fasten below the prop hub? Do you just have a small notch for the piano hinge where the "mouth" would normally be?
gammaxy wrote:Hoping to make it up to Wisconsin when it starts warming up for some transition training.
Users browsing this forum: No registered users and 47 guests
