mike.smith wrote:I just have an in-line fuse. If there is an over voltage the fuse breaks the circuit.
Rynoth wrote:I installed the full overvoltage/relay kit that Noel linked above, and the amp draw is indeed very low when engaged.
NWade wrote:mike.smith wrote:I just have an in-line fuse. If there is an over voltage the fuse breaks the circuit.
Fuses are great at protecting against over-amperage (AKA over-current) conditions; but AFAIK they don't protect against a voltage rise, such as what happens when your voltage regulator fails.
--Noel
--Noel
The fuse is between the VR and the battery. I know it works because a couple of years ago there was an issue with the stator, and the fuse blew. Fixed the problem and replaced the fuse. No damage to the battery or the rest of the electrical system.
--Noel
Fuses are by no means a guarantee against over-voltage, they are intended to limit current.
Kai wrote:Speaking of which: I have a solid state Icom 200 COM in #0525, and a King KT76A TPX (not solid state). In fact, it is the third TPX; the others have failed with depressing regularity. They fail when for some reason I need to stop the engine and forget to switch off the avionics. When I start the engine again, and then release the starter switch: scratch one TPX. I am am told releasing the starter relay produces over voltage in the system that kills the 'cavity' in the TPX. Is this true? Comments? Is there any way to protect against this? (apart from switching off the avionics bus). Thanks.
Users browsing this forum: No registered users and 43 guests
