mike.smith wrote:rizzz wrote:Mike,
Check out this post on the legendary Bob Hoover VW blog:
http://bobhooversblog.blogspot.com.au/2 ... -seal.html
It might explain some things.
Sounds like the AeroVee manual would benefit from some of these tidbits of wisdom!
I know my oil return hole is clear. I check that every time with a long pipe cleaner. As for installing the rear seal, pretty much everyone I know has done it with a rubber mallet or a mallet and a block of wood. I've removed 2 seals, and in both cases there was no damage, no nicks, no cuts and no sign of leaks coming from the seal. There was evidence of leaks coming from around the 8 pins that hold the flywheel. I'm letting the RTV set up for at least 36 hours (instructions say 24 hours) before trying the engine again.
By the way, for all us male type individuals, did you know there are "instructions" on the tube of RTV? And did you know that after applying RTV you are supposed to wait a full hour before tightening the parts and torquing them? This guy explains it pretty much like the instructions do:
https://www.youtube.com/watch?v=21CvanhKILA
I found the video made by the makers of RTV and Right Stuff to be pretty interesting, too, though if they say their Right Stuff is the best product to use, I'm not sure why they make all the other products:
https://www.youtube.com/watch?v=h_y9FTicNnM
Klimek wrote:There is caution given about using RTV under the cylinders on the AeroVee and certified engines. Theoretically the ultra thin layer remaining can cause cylinder movement and later failure. Is there the same possibility of flywheel to crank movement and failure?
Klimek wrote:How much red goo do I use?
