Re: Throttle cable push back
Aldo wrote:Thanks Chris, Bill and Bryan! It sounds like what is going on is very normal. I have the push/pull style as well - so even more likely there is no problem. If you don't mind another simple question:
Is it also common for the mixture cable to result in no noticible leaning until it is pulled out a significant distance? Without measuring, I would estimate I pull it out about half way before noticible leaning starts.
Mine creeps unless I lock it down fairly tight. Even tight, I have no problem advancing or retarding the throttle under normal conditions. I only notice it when I'm on the ground and am trying to finely set my RPMs for warmup or taxi. Not a bid deal, but I notice it then.
