sonex892. wrote:Wow! That engine must have been running ultra smooth Bryan.
Area 51% wrote:Has the adapter plate been resting on the mount tubes? I helped a Xenos driver replace his sagging rubbers and found the plate had rubbed a nice groove in the mount tubes.
After seeing that, I installed a sacrificial aluminum sleeve over the tubes on my mount.
Bryan Cotton wrote:So my alignment with the cowl is off and I need to pull the engine off to distribute bushings. I'd really like to avoid pulling off the baffles. I'm considering a 3 point sling - around the two intakes and the prop shaft. Any experience or thoughts?
Bryan Cotton wrote:Area 51% wrote:Has the adapter plate been resting on the mount tubes? I helped a Xenos driver replace his sagging rubbers and found the plate had rubbed a nice groove in the mount tubes.
It had not been resting on the tubes.
Users browsing this forum: Google [Bot] and 17 guests
