Spinnetti wrote:Automotive "thermo time switches" are well proven for this. Car fans run when the car is off based on a temp set point. Very simple/proven solution.
Brett wrote:Does it even need to cool down after? If running in general over 100f less then shutting down with no cooling the post temps obviously will rise but to a point over the critical temp the turbo have been slowly siezing at? I suppose I'll need to re read the graphs and look at my oil spec charts.
tljones42 wrote:For those of you who have started working on the turbo water cooling, I started to construct the plenum for the radiator today and discovered the plans dimensions are too short for the radiator depicted in the Sonex photo (which I have). After using the radiator as a length template I later discovered that the 5/16 inch dimensions for the inlet and outlet cutouts are too small. If you haven't tackled this yet, save some time and use the radiator for a pattern for both length and inlet and outlet cutouts.
Tom Jones
Onex 0138
