Time-Sert all the holes?
Postby Art Tiller » Sat Jul 13, 2024 10:25 am
Hello All, From the builder, I purchased his Sonex with the AeroVee 2.0 engine. I started the condition inspection last month. (June 2024) I have been addressing several issues. Installed bigger 500-5 main and 6 inch tailwheel tires.
Turning my attention to the engine, I learned a very important lesson. Remove intake manifold before screwing around with the upper spark plugs.
So, here is the thing. I am going to repair my stripped out threads with a Time-Sert. In the mean time I have ordered two new heads and I plan to install those and save my old ones as spares.
Have you ever heard the saying "Don't fix it if it isn't broke"? I am tempted to "fix" all 8 spark plug holes, even if 7 are still good. What do you guys think. It will be a winter project as I tend to procrastinate some.
Art Tiller
Sonex N568SX
Second Owner
Sonex 0568 Taildragger, AeroVee,
Kansas City, MO
https://youtube.com/c/ArtTiller
Art Tiller
Re: Time-Sert all the holes?
Postby Outlaw6 » Sun Jul 14, 2024 10:46 am
Yes, and the exhaust manifold holes also (at least on the turbo).
Waiex N176WS (Tri-Gear Aerovee Turbo)
Outlaw6
Postby n502pd » Tue Jul 16, 2024 6:39 pm
Hi Art! when I built my engine, s/n 870, I did indeed timesert all plugs, and have had no problems or concerns since. the stripped hole should clean up and be ready for the timesert tap and installation tool. Of course follow the directions. you should have a good set of heads afterwards!
Joe Nelsen
scratch built :D
Flying @78.2
KGYI/N. Tx Reg/Perrin Field
n502pd
Postby Bryan Cotton » Tue Jul 16, 2024 7:57 pm
After hearing the horror stories, I had planned to timesert all 8 holes at rebuild (or sooner if needed). But here I am, 270 hours, and all the plug holes are fine. The #3 and #1 valves & seats, not so much. So I don't think it is a have-to item, but if it makes you feel better then go for it.
Postby Art Tiller » Tue Jul 23, 2024 12:38 pm
I am horrified that I got my nomenclature mixed up. In my original post to this thread I said, "Remove intake manifold before screwing around with the upper spark plugs". What I meant to say was, "Remove Intake Elbows before screwing around with the upper spark plugs". I apologize to anyone that thought I was referring to the actual "Y" shaped intake manifold tubing that runs from the AeroCarb to each of the two intake elbows.
I was studying up on the cylinder head installation when I realized my mistake. Next time I will use a much more technical description like "little red thingy that sits on top of the cylinder head". :)
Art Tiller
Sonex N568SX
Second Owner
Kansas City, MO
Art Tiller
Postby SonexN76ET » Wed Jul 24, 2024 4:57 pm
Please be careful removing and reinstalling the intake elbows. I don’t recommend you remove them while removing the top spark plugs. Each time you remove and reinstall the intake elbows you create the risk of an induction air leak that will lead to a cylinder running lean and therefore hotter than it should. Just be careful with the spark plug installation. Make sure you properly seat them, screw them in initially with your fingers, make sure they are not cross threaded before you apply torque with a socket. If you have to put a time sert in later it is easy to do. I would not do all of the spark plug holes as time serts because there is not much distance from the bottom and top plugs to the valve ports. If you end up taking too much material out when prepping the time sert hole, you may end up too close to the valve ports and then you will likely get a crack.
Jake
Sarasota, Florida
SonexN76ET
Postby Bryan Cotton » Wed Jul 24, 2024 7:21 pm
On my airplane I either have to remove the elbows or the baffles to get the top plugs. My elbows have been off a zillion times. I have not found it to be a big deal.
Return to Second Owner Issues
