New: Rotax/Sonex Cooling Kits Available!
Rotax 912 series discussion.
Postby Skippydiesel » Fri Jul 12, 2024 12:38 am
The new system looks great BUT seems only to address half (Coolant) the liquid cooling requirement.
Where is the oil cooler? - hidden in the ducting? or somewhere else entirely?
Skippydiesel
Re: New: Rotax/Sonex Cooling Kits Available!
Postby Murray Parr » Fri Jul 12, 2024 1:07 am
The oil cooler looks to be in front of the coolant radiator, I wonder if you could put the oil cooler behind instead. My oil takes forever to heat up enough for takeoff but the coolant quickly overheats and could possibly help speed up warming the oil. Maybe they tested this already or maybe not.
Murray Parr
WXB0015
Rotax 912ULS
MGL Explorer Lite
First flight May 6/23
RV9 builder (Sold)
Murray Parr
Postby Skippydiesel » Fri Jul 12, 2024 3:55 am
Ahhh I should have looked further at the additional photos.
Oil cooler appears to be where you found it. It wouldn't be hard to fit a small, pilot condoled, flap/shutter to the exit air - that would certainly speed the warm up.
Skippydiesel
Postby ampzapper » Fri Jul 12, 2024 11:36 am
Their full install kit includes an oil thermostat. That could help with warmup.
ampzapper
Postby Skippydiesel » Fri Jul 12, 2024 6:10 pm
ampzapper wrote:Their full install kit includes an oil thermostat. That could help with warmup.
While I can see the potential benefit in an oil thermostat, in particularly cold climate. They add significant weight & complexity, to the oil reticulation system, as such should be avoided.
Skippydiesel
Postby CaseyCooper » Sat Jul 13, 2024 1:02 am
Hello folks,
The cooling assembly houses both the oil cooler and radiator. The thermostat opens at 180f and weighs about 8 ounces. When warming up my engine, whether summer or winter, it takes exactly 5 minutes on the dot to achieve operating temperature. With a peak oil pressure of 70 psi while the valve is restricted and bypassed (it allows 10% of the oil to flow through oil cooler until warmed up and the rest to flow through the engine normally) and a minimum oil pressure of 55 psi, the system works perfectly within Rotax's specifications. While you could add a manual baffle of some kind, a thermostat is automatic, recommended by Rotax, less complex, and the same weight if you were to design such an assembly. While flying just this evening with 105 degrees OAT, I was seeing max temps of 225 for CHT's and 210 OT. With hundreds of hours on this combination, I have complete faith in the system.
We're gearing up for our 4th trip to Airventure this year and looking forward to seeing everyone there!
PS: I hope you're enjoying building some time in your Waiex Murray! That thing looks wonderful!
N7777X
Tailwheel
Rotax 912
3 blade Warp Drive
CaseyCooper
Postby Skippydiesel » Sat Jul 13, 2024 2:33 am
Hi Cadey,
"...........a thermostat is automatic, recommended by Rotax,"
Please give me the Rotax manual/chapter/page where Rotax recomend the installation of an oil thermostat?
Skippydiesel
Postby Skippydiesel » Sat Jul 13, 2024 2:34 am
Hi Casey,
Skippydiesel
Postby sonex892. » Sat Jul 13, 2024 3:38 am
Skippydiesel wrote:Hi Casey,
I found it recommended in the 214 page rotax install manual. Its at page 184.
I'm going through all this at the moment trying to fit radiator, oil cooler etc in a sonerai.
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby CaseyCooper » Sat Jul 13, 2024 1:44 pm
Skippy,
Steve beat me to it! There’s some fine print to it but SL912-011 will help clear things up.
Steve! A Rotax powered Sonerai is going to be a blast. I can’t wait to see how your project progresses.
N7777X
Tailwheel
Rotax 912
3 blade Warp Drive
CaseyCooper
Return to Rotax
Users browsing this forum: Google Adsense [Bot] and 5 guests
