First Start
Rotax 912 series discussion.
First Start
Postby Skippydiesel » Thu Jul 28, 2022 4:23 am
Exciting moment - I started my brand new Rotax 912 ULS for the first time yesterday.
Everything went very well:
    Ambient 14C
    Engine fired immediately & ran smoothly. Engine speed increased as it warmed up.
    Idling too fast, 2300 rpm - easy fix.
    EGT's almost equal - this should come good with pneumatic carburettor balance.
    Good oil & fuel pressure
    Took engine to oil temp 57C & coolant 60C
    Charge 12.6V 2 amps
Post engine inspection reveled a small fuel leak, from the connection to a fuel flow sensor - refitted with gas grade thread tape - fixed!
Will do a rough idle speed adjust down & check hydraulic lifters are all fully "primed" with appropriate clearance as per Rotax "purge" instructions.
Next start, will be with cowling fitted and once warmed, will fine tune the idle & do the pneumatic balance.
The excitement is almost too much to bear.
Skippydiesel
Re: First Start
Postby xeriotti » Tue Aug 09, 2022 12:36 pm
Show us that baby!!! :)
xeriotti
Re: First Start
Postby daleandee » Tue Aug 09, 2022 7:24 pm
Skippydiesel wrote:Exciting moment - I started my brand new Rotax 912 ULS for the first time yesterday.
Good deal on the first start! Great engine and very reliable.
BTW ... I'm not a fan of using any kind of tape (especially Teflon) on fuel fittings as pieces can be torn loose and get into the fuel system. A small piece can clog an orifice and cause problems. Silicone sealer on fuel lines is also a horrible idea.
Permatex makes Aviation sealant especially for fuel line fittings.
Re: First Start
Postby Bryan Cotton » Tue Aug 09, 2022 10:10 pm
I used ez-turn per Joe Norris' recommendation. I think the Aerovee manual also calls out teflon paste. I also avoid teflon tape except for house plumbing and shop air.
Re: First Start
Postby 13brv3 » Wed Aug 10, 2022 10:36 am
Congrats on the first run! It sounds like it was as successful as you could ever hope for. The flying Rotax thread has been pretty lonely recently :-)
Rusty (912UL Onex)
Rusty
Onex- Rotax 912 (130 hours and counting)
Fixed wing, gyroplane, A&P
13brv3
Re: First Start
Postby Skippydiesel » Wed Aug 10, 2022 7:25 pm
13brv3 wrote:Congrats on the first run! It sounds like it was as successful as you could ever hope for. The flying Rotax thread has been pretty lonely recently :-)
Rusty (912UL Onex)
Hope to add to the "flying Rotax thread" within the next few weeks. Aircraft essentially complete - just trying to get coolant temperatures under control.
Skippydiesel
Return to Rotax
