Temperature (H2O & Oil) sensor electrical connectors
Rotax 912 series discussion.
Postby Skippydiesel » Thu Dec 02, 2021 2:45 am
Hi Brains Trust,
Even my local Rotax dealership doesnt know what these are called or where I can get them.
They are the slide on electrical connectors that attach to the "disk" on top of the oil & water (head) temperature sensors .
I have seen at least two types; a push on and a pull on. They both resemble an ordinary female spade connecter BUT have an additional spring loaded retaining system (lock on).
Any assistance with:
[list=]Correct name
Part number
Supplier[/list]
will be much appreciated
Skippydiesel
Re: Temperature (H2O & Oil) sensor electrical connectors
Postby Oshpilot » Thu Dec 02, 2021 4:03 pm
Pretty sure what you’re looking for is a “Series 56” connector. Common in automotive electrical, as I’m finding out while replacing the wiring harness in my 65 GTO! Common sizes are 2.8, 4.8 and 6.3mm. The 6.3 is the common ¼” female or male locking spade terminal. A google search will yield many suppliers, though automotive are usually more likely i.e. Jegs and similar.
Wayne, Oshkosh, Sonex N444SX, Conventional gear, Jab 3300, Enigma
Oshpilot
Postby Skippydiesel » Thu Dec 02, 2021 4:52 pm
Thanks Osh - will follow up.
I received a lot of "fix" type advice (shrink tube/silicon glue/etc) rather than using an appropriate part.
Skippydiesel
Postby sonex892. » Thu Dec 02, 2021 6:06 pm
$17 aud. With enough for 50 rotax motors
https://www.sparesbox.com.au/part/narva ... 0qEALw_wcB
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby Skippydiesel » Thu Dec 02, 2021 10:46 pm
sonex892. wrote:$17 aud. With enough for 50 rotax motors
Thanks - have ordered - with delivery now $27/100pk - anyone interest in trying them ? You will need 3/Rotax 9 series.
Skippydiesel
Postby Skippydiesel » Sat Dec 18, 2021 5:00 am
Connectors have been delivered.
Three installed (coolant/head temp X 2 and one oil temp),
Seem to be very effective - slip on quit easily but hard to remove until spring depressed.
Definitely the right part for job.
Skippydiesel
Return to Rotax
