Herraripower wrote:I have a 64” 3 blade warp drive
Herraripower wrote:So I had an epiphany, my mounts. So i took the bolts/pins out and inspected my mounting surfaces. My front attach points on the attach bars, were resting on my mount bolts. The bushings had shifted and deformed allowing this to happen.
So upon recommendation by Mark at Sonex, I shimmed the outside bushings with more washers, and in this case, I used washers that were dished to encapsulate the bushings, and push them in tighter against the attach bars. I also noticed the front attach points (the engine mount) flex outward and inward slightly, about 1/8 of an inch, which can equate to a lot of movement at the engine. I flew it for 3 more hours and no luck in solving the problem.
SonexN76ET wrote:I am questioning why Sonex did not have the pins from the outboard side of the engine mount the bolts go through not carry over to the inboard side for the bushings to slide onto as they do with the AeroVee mount? I am also wondering if Zach’s solution to put a 4130 spacer over the bolt between the inside of the bushing would be a good solution or if that should be welded to the mount like on the AeroVee mount?
Zach - I am referring to your earlier post and pictures.
http://www.sonexbuilders.net/viewtopic.php?f=60&t=5612
Jake
Hi Zack,
Our original assembly did use an AN4 bolt to support the engine and that is fine. We have a newer design that changed the wall thickness of the tubes that accept the bolts and now use AN5 bolts.
What you have done conforms to a proper adaption of the AN4 bolt installation.
Blue Skies….
Kerry
Herraripower wrote:Zach,
But yes, the red bars have worked apart and torn up the rubber allowing them to rest on the steel sleeves on the an5 carry through bolts.
SonexN76ET wrote: install polyurethane bushings
