Relay for Start Switch Circuit?
Posted: Sun Aug 16, 2020 10:32 am
Has anyone added a relay between their start switch and the starter solenoid in order to use a smaller start switch and smaller wires to the switch?
I hadn't really given it much thought until now when I'm actually running wires. I'm using this switch:
https://www.steinair.com/product/engine-start-switch/ , which has solder tabs on the back which look a bit puny to attach the spec'd 14 awg wires to.
Also, after reading through this thread: viewtopic.php?f=6&t=5430&p=41070& , it sounds like the start circuit gets subjected to pretty high current momentarily. I don't think I should try to send 30+ amps through this switch. However, it's a really nice button and I already drilled the big hole for it so I want to use it!
Seems like it would be pretty simple to use like a 40 amp relay but I'm curious if anyone has sourced a particular relay for this purpose or has any examples of how they wired it!
