Aiming taxi & landing lights
Postby Bryan Cotton » Sat Oct 12, 2019 9:31 am
Hey all,
I'm hoping to test out my landing lights electrically soon. I'd like to have a reasonable first pass at aiming them. Does anybody have a procedure like park X feet from hangar, beam center is y feet high?
Re: Aiming taxi & landing lights
Postby mike.smith » Sat Oct 12, 2019 10:09 am
I just waited until night time and parked on the taxiway to see what I could see. With a tail dragger, if you only have one light, you're going to have to choose the best angle for landing or the best angle for taxiing. I don't know of a good way to decide the angle for landing other than giving it a try. On approach you get one best angle, and on flare you get a different best angle (probably about the same as the best angle for taxi, since in both cases the tail wheel is on the ground). So take your pick.
Postby Bryan Cotton » Sat Oct 12, 2019 1:04 pm
Thanks Mike. I have two lights. Most of the useage will be in the day with wig wags going. I'll set one on the taxiway and one a little lower, I would assume.
Postby mike.smith » Sat Oct 12, 2019 1:16 pm
That's the ideal setup! :-)
Postby Fastcapy » Mon Oct 21, 2019 10:16 pm
I have mine set with one lower and one higher. When landing I flip my switch up which turns on both lights, when taxiing I can flip the switch down and just taxi with the taxi light on the left wing.
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Return to Electrical System
