Red Cube Transducer Install Location
Postby rdsafe » Sat Aug 27, 2016 3:10 pm
Where are you successfully installing your fuel transducer? In front of the firewall or behind it?
In front of the firewall - it will be in all that heat and possible running up hill as it should.
Behind the firewall - out of the heat; but running down hill quite a bit.
The instructions that I've come across state that it should be installed in a level plain with straight lengths of pipe on both ends and no sharp bends close to the transducer.
With the AeroVee engine there's no pulsation from a fuel pump the bother it.
I'm leaning toward behind the firewall; but wonder if it will read properly.
Richard
rdsafe
Re: Red Cube Transducer Install Location
Postby Bryan Cotton » Sat Aug 27, 2016 4:00 pm
I don't understand how it could read different based on location. Flow is the same at all points in a closed system. We use a lot of flow transducers at work.
Postby peter anson » Sat Aug 27, 2016 9:40 pm
I think the idea of the uphill flow is so vapour bubbles don't get trapped in the flow meter. I have my meter flowing uphill in the engine bay but it's wrapped in a little blanket of fire-sleeve. It's after an electric diaphragm pump and gascolator and before the engine fuel pump. Seems to work fine.
Sonex 894, Jab 3300 with Bing carb
Return to Electrical System
