ScottM-Sonex1629 wrote:Working thru my electrical wiring now. I have the recommended DPST switch in the panel for the AeroVee Magnatron ignition circuit.
Question on the type of wiring to use from the poles of the switch to the P-leads on the upper and lower mags. The AeroVee manual calls for 20 ga wiring minimum. Should it be shielded or is normal AWG wire okay?
