shielded strobe wire connectors
Postby sport65 » Sun Sep 07, 2014 10:24 pm
I put my wings on for rigging the other day and it made me start thinking about wiring the nav/strobe lights.
The led strobe lights have shielded wiring. I want to install a quick connect plug at the wing root, to facilitate wing removal. What type of connector do you have to use for this with the shielding? I was told by a friend to use a normal connector and connect the shielding into the connector as a wire would be. I guess this leaves the plug connector unshielded. Does this sound correct? or is there another way?
Thanks Jeff
Jeff
Sonex 1570, standard gear, matco independant brakes and wheels, aileron trim, MGL iefis, V6 radio, Uavionix adsb, stx-165 transponder, Jabiru 3300
Finished
Ponder Tx
sport65
Re: shielded strobe wire connectors
Postby Bryan Cotton » Sun Sep 07, 2014 11:17 pm
Jeff,
That sounds correct. If you had MIL 38999 connectors you might terminate the shield to the backshell and preserve the shielding through the connectors. Just stay away from aircraft carriers. Seriously, if you make reasonable effort to minimize the unshielded length you will be fine. I have worked with shielded wire in my aerospace career for a long time.
Postby sport65 » Mon Sep 08, 2014 10:41 pm
Thanks Bryan ! Not familiar with MIL 38999 connectors but I assume they are metal cased. I'll look for something like that, but it's good to know normal connectors work and how to do it correctly.
Thanks allot!!
Jeff
Finished
Ponder Tx
sport65
Postby wlarson861 » Tue Sep 09, 2014 4:16 am
I used Molex connectors that I got from Radio Shack. They are white plastic with multiple pins.
Bill Larson
N861SX
wlarson861
Postby Bryan Cotton » Tue Sep 09, 2014 7:18 am
Molex connectors will work good for that. I was only kidding about using 38999 connectors. They are expensive. Good option if you have a Blackhawk or F16. With LED strobes you will not have a lot of current. Keeping the unshielded part short through a molex connector would work fine. Don't hunt for a metal connector.
Postby sport65 » Wed Sep 10, 2014 4:46 pm
Thanks guys! Got the molex connectors at radio shack!
Jeff
Finished
Ponder Tx
sport65
Return to Electrical System
