Re: Skytec starter amps
Area 51% wrote:Rynoth wrote:You had the starter circuit open while engaging the starter solenoid? Makes me wonder if the solenoid circuit might draw more amps for some reason if the starter doesn't actually have its own power.
Never gave that a passing thought. Didn't think it would matter if there was power flowing through the starter motor contacts or not.
It seems the second set of windings in the solenoid someone mentioned would have to get it's power from the main cable somehow.
I'll do a bench test to check though.
Yea that's what I'm wondering, maybe the initial draw or "spike" for the solenoid is reduced when the main starter power takes over from there, and without the power on the starter the solenoid circuit has to try "extra hard" to keep pushing on the solenoid. That, and/or the starter motor is trying to pull amps through the start-button circuit in the absence of its own main battery circuit. I'm curious what you find!
