Hinge pin
So, I have completed the vertical stabilizer on the Sonex Model B.
The hinge pin slides easy into the hinge on the Vert Stabilizer.
I have completed the rudder.
The hinge pin slides easy into the rudder.
BUT
When I try to put them together, it is a nightmare!
I have made a point on the pin, I lubricated the pin BUT it is still very difficult to install the rudder on the vertical stabilizer.
Is this OK? With a bunch of fighting, I can get the two together AND the rudder moves smoothly when installed.
Even though the rudder moves smoothly, will this wear out the hinge pin prematurely?
Thanks!
BUT
Thanks!
