Windshield seal
Windshield seal
Postby Murray Parr » Tue Nov 17, 2020 3:56 am
Does anyone use a sealant to seal the windshield? I imagine any rain would just leak past the skirt and into the cab. What, if anything have others done to prevent this or am I just worrying over nothing?
Murray Parr
WXB0015
Rotax 912ULS
MGL Explorer Lite
First flight May 6/23
RV9 builder (Sold)
Murray Parr
Re: Windshield seal
Postby Matt541 » Tue Nov 17, 2020 9:04 am
I used Permatex Ultra Black on the leading edge of my legacy Sonex, but that one's out in the elements whereas I believe the B model is covered. Some of my reasoning for doing that was for water, the rest being that I noticed some daylight between the firewall, mounting strip and windscreen and was concerned about CO.
Matt541
Re: Windshield seal
Postby GordonTurner » Tue Nov 17, 2020 11:11 am
Hi Matt
1. Did you select permatex black for any particular reason?
2. Is it really visible or not noticeable?
Thanks, Gordon
Re: Windshield seal
Postby Matt541 » Tue Nov 17, 2020 11:33 am
Hi Gordon!
1.For starters, Ultra Black is my go to silicone for most things. Heck, I just used it to "pot" connections on my ignition box. But more importantly, it's non acetic, so I'm not worried about it etching/ damaging whatever surface I use it on. (How to tell? If your silicone smells like vinegar, it's acetic.)
I'm honestly not 100% sure if an acetic silicone would damage lexan or plexi. I've used them in other applications without noticing an issue. Metal is a different story. I would love to hear other people's thoughts on that.
On a legacy, the leading edge of the windscreen is right along the firewall, so the Ultra Black being fuel and oil resistant is a big plus. The larger can version would make it much easier to apply than the tubes, wish I used that one instead. It's the 9.5 oz "Power Bead" can. So far, it's not drying out between uses either.
( https://youtu.be/j4y1PbkzwRo?t=290 This is using the can version, not going back to the tubes. There's an Amazon link in the video description if your local auto parts store doesn't have it. But they should.)
2. It all depends on how well you do it. Get someone to give you a hand, that was a mistake I made. Done properly, it spreads out evenly to the edges of the strip and screen and actually isn't noticeable at all. (Actually gotten some comments to that effect.) You can smooth out the leading edge just like caulking a tub. If it doesn't come all the way out, you can back fill it and smooth again. (I had to do that in spots.) In fact, I used the same silicone "squeegee" I use on tubs...
Matt541
Re: Windshield seal
Postby SonexN76ET » Tue Nov 17, 2020 4:44 pm
I used the thin silicone chaff seal from Aircraft Spruce between the windscreen and the airframe. I think it is 1/16 inch by 1 inch.
Also on the windscreen strap I used the soft side Velcro to form a seal. It is the Velcro with the heavy duty adhesive backing.
Jake
Sarasota, Florida
SonexN76ET
Re: Windshield seal
Postby GordonTurner » Tue Nov 17, 2020 8:09 pm
Hi Jake
The Velcro on the windscreen bow. Have you flown in any rain? Does it keep that out?
Gordon
Re: Windshield seal
Postby Murray Parr » Wed Nov 18, 2020 3:23 pm
Thanks for the responses, I think I will try the Permatex ultra black :-)
Murray Parr
WXB0015
Rotax 912ULS
MGL Explorer Lite
RV9 builder (Sold)
Murray Parr
Re: Windshield seal
Postby Matt541 » Thu Nov 19, 2020 8:52 am
No problem, let us know how you make out with it on the B model. Cheers!
Matt541
Re: Windshield seal
Postby SonexN76ET » Thu Nov 19, 2020 4:07 pm
The soft side Velcro on the windscreen strap is about 95% effective keeping the rain out. I get a few drips in the center when flying in rain.
Jake
Sarasota, Florida
SonexN76ET
Re: Windshield seal
Postby GordonTurner » Thu Nov 19, 2020 11:03 pm
Thanks Jake
Return to Sonex-B / Waiex-B
