by pfhoeycfi » Tue Mar 10, 2020 7:55 pm
I'll be operating much of time out of the glider club field which is grass, pretty good condition. I'm used to bouncing around on the big pawnee tires...or in the L19. My B will have the larger tailwheel and I would like to go with bigger tires up front. I'm looking at the Condor 6 ply 5.00 x 5 on spruce, 5.5 lbs. The 4 ply is the same spec weight. Any general thoughts, recommendations, issues? The tires, along with the whelen tip lights, will likely be my only off plan adds.
When it gets a little warmer the wings will come up through the living room floor..I'll plug them in and get the holes drilled. That step is holding things up alot...
peter
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
