Canopy Lock Pin
Canopy Lock Pin
Postby Airwolf » Tue Apr 02, 2019 10:19 pm
Does anyone have a picture of where they located the canopy lock pin shown on the WXB-D01 (I'm guessing it is on the Sonex-D01 as well)? I'm having trouble seeing where on the latch and longeron the plans recommend.
Thanks in advance!
Airwolf
Re: Canopy Lock Pin
Postby mike.smith » Wed Apr 03, 2019 10:39 pm
Re: Canopy Lock Pin
Postby GordonTurner » Thu Apr 04, 2019 2:00 pm
Has anybody come up with a better way than the pin? Is there someway to include a spring in the mechanism so no pin is required to hold it in the closed position? Not quite there yet, but wondering.
Gordon
Re: Canopy Lock Pin
Postby Bryan Cotton » Thu Apr 04, 2019 4:11 pm
GordonTurner wrote:Has anybody come up with a better way than the pin? Is there someway to include a spring in the mechanism so no pin is required to hold it in the closed position? Not quite there yet, but wondering.
Gordon
My canopy has a spring and the pin, per the plans. Belt and suspenders - I like it.
Re: Canopy Lock Pin
Postby mike.smith » Thu Apr 04, 2019 11:00 pm
You really need a positive lock for any canopy. A spring alone isn't safe, IMHO. The pin I show in my Kitlog site is simple and effective.
Re: Canopy Lock Pin
Postby DCASonex » Fri Apr 05, 2019 8:42 am
One thing you can do with the cheap pin that Sonex shows is to also use it through a simple bracket around the toggle lever of as simple master circuit breaker to pin it in the off position. Then the pin has a useful place when both flying and on ground. Almost makes that cheap pin look like a good idea.
Re: Canopy Lock Pin
Postby Onex107 » Fri Apr 05, 2019 9:26 am
How do your rescuers get it out when you are upside down and unconscious?
Canopy Lock Pin
Postby Tnhelm » Fri Apr 05, 2019 9:38 am
Canopy locking
Check out Airward.com. They have a spring loaded latch to eliminate the locking pin.
Tnhelm
Re: Canopy Lock Pin
Postby Bryan Cotton » Fri Apr 05, 2019 9:45 am
Onex107 wrote:How do your rescuers get it out when you are upside down and unconscious?
How do you get out when it is upside down period?
Re: Canopy Lock Pin
Postby builderflyer » Fri Apr 05, 2019 9:59 am
At least two Sonex that I am aware of have had the canopy come open in flight when a locking pin was not used. Both aircraft made it back to the runway but not without a flight that anyone one would choose to repeat voluntarily. A spring, alone, will not necessarily keep the canopy closed.
Art,,,,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,,,Jabiru 3300 #261
builderflyer
Return to Sonex-B / Waiex-B
