Murray Parr wrote:Tim,
Do you have the rudder pedals installed? I had no problems with drilling the glare shield to the longerons, however, I had the fire wall off, and used a tight fit angled drill. If you don't have access to one of those, you could try using a long drill bit and use the bit of flex in the bit to help drill the hole square. I won't be riveting the fire wall on until I am finished most of that area under the glare shield. Take the rudder pedals out would help too
Hope this helps
Murray
Hope this helps
Murray
