by pappas » Sun Sep 05, 2021 11:32 am
I have a Vertical Power VPX Sport handling all of my electrical systems fusing and power routing tasks. It is adjustable and I can set any amperage I want for the components. I set my flap fuse limit at 7.5.
I set flap presets at 10, 20, and 30 (actually 27 degrees, I don't think anyone gets the full 30 with the actuators we have). I touch the stick-mounted switch once for each next downward stop and the actuator will go directly to the selected stop. One touch upward, and the flaps go all the way up to zero.
The VPX allows me to limit travel, (an adjustable setting), to a final up and a final down stop. However, I can control my flaps without presets from my EFIS, similar to a panel-mounted switch. I noticed that if I hold the manual switch for too long at the top or bottom of travel, the fuse will pop. I think that is what is happening to you. In an effort to make sure that the flaps are all the way up or all the way down, you may be holding the switch a little too long which overloads the circuit and blows the fuse.
I also noticed in your video that if your initial digital reading is 2 degrees and your final reading is 27 deg, you may only have 25 degrees of down flap. I used the same digital level to set mine up. As long as the dirty stall turns out to be in the 44-46 mph range you are probably ok.
I also noticed that the plans called for a 3-inch pushrod. No, way too long! I think the plans are wrong. Mine is almost the same as yours.
Remember that if you have more than 2 and 29/32 inches distance above the leading edge as a flaps neutral starting point, that will mean that your flaps trailing edge is actually hanging down a bit into the airstream. Like flying with 2, or so, degrees of down flaps all the time. It took me a while to get that right but it made a big difference for me in the air. Less than 2 29/32's and you will have reflexed flaps). I tried reflexing the flaps for better cruise. It gave me next to nothing in speed and made the stall speed higher.
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
