Lbrandt wrote:Lbrandt wrote:Murray Parr wrote:Tim,
Do you have the rudder pedals installed? I had no problems with drilling the glare shield to the longerons, however, I had the fire wall off, and used a tight fit angled drill. If you don't have access to one of those, you could try using a long drill bit and use the bit of flex in the bit to help drill the hole square. I won't be riveting the fire wall on until I am finished most of that area under the glare shield. Take the rudder pedals out would help too
Hope this helps
Murray
Area 51% wrote:Hey Gregg.....
Did you and your dad fly a T41 out of Grant Airport?
magicpilot wrote:Hi,
I probably can make some pictures tomorrow night ... .
Just as side note ... Sonex sent me a new windshield somewhat last year saying the tinting wasn‘t right but it was rather that the cut was different especially around the fuel door - just saying - I hope you have the right cut - but I really try to sent u pictures of mine as it is installed.
Cheers
