Re: B-Model conversion
That's great news, John. It was great to see you at OSH. Sorry to have been so busy and working with such short time. Keep us posted on that conversion!
A Forum for Sonex Aircraft Builders and Enthusiasts
http://sonexbuilders.net/
fastj22 wrote:
Update....
Off with the old, on with the new.
I've had to pull back the vinyl to make clean rivet/bolt attachments. I'll probably pull the entire wrap off, strip the paint (which I should have done anyways), and re-wrap. Going to attack the wings next.
NWade wrote:fastj22 wrote:
Update....
John - Given how far you've gotten on your conversion, I was wondering: Do you think the new B-model style of lowered seat-pan and control-yoke/push-rod arrangement could be applied to a Legacy Sonex?
I can't swing a B-model conversion, but as my bird nears completion I'm finding that I'm about 1" too tall in the torso to fit my legacy Sonex with the standard seat and a center stick. I really don't want to put in dual sticks in order to accommodate the lowered seat mod; but the B-model gets both a lowered seat _and_ the center stick, doesn't it?
--Noel
Sonex #1339
fastj22 wrote:Converting a standard A model seat to a lowered seat would require a fair amount of fabrication and rework. The C channels supporting the seat are smaller and the aft attach point for the pan is moved back. I could harvest the aft attach off my old A model and send it you if you'd like. Its going into the scrap heap anyways. Have you considered just flying your bird seated center with your feet on the outer pedals?
