Triggerfish wrote:Picked up a partially built Onex and am trying to figure things out. This is an older kit 121. It has 2 pieces that make up the elevator control rod, but I can not find anywhere on the plans as to how to connect them. I assume there is a sleeve either inner or outer which slides in or over the junction and it is glued and bolted.
Any help is appreciated
GeorgeM
121
Triggerfish wrote:Hi Wes
Thanks for getting back to me. I do understand what you described, however , I guess I was not clear enough.
If I look at c03-07 the drawing shows the elevator control rod as one piece being 78.944 inches long. My problem is that I have 2 pieces about 39.5 inches long. So I'm assuming they need to be connected together. My question is how? I can glue a sleeve over them and also thru bolt each piece with an an-3 or I can put the sleeve inside and do the same.. I can't find any info on the drawings.
GeorgeM
