Tnhelm wrote:I use a 10 gallon tank with a hand pump on it. Purchased at Northern Tools. I am able to carefully fuel while monitoring the tank level and hand pump speed. A secondary advantage is that I can reverse pump when I need to empty the aircraft tank. I once overfilled the tank while using a regular aviation fuel pump but because the tank is inside and under the windscreen, the over flow fuel just went on the glareshield, not the windscreen. (Actually better than the standard Sonex set up)
https://www.northerntool.com/shop/tools ... _200711544
Tom Helm
OneX0137
Users browsing this forum: Bing [Bot] and 10 guests
