by 13brv3 » Thu Dec 09, 2021 9:43 pm
Greetings,
OK, so the Onex has been out quite a while now. Has anyone tried both wingtip lengths and recorded the difference in climb and cruise for each? I seem to recall something about the shorter tip not meeting the stall requirement for sport pilots, but I'm not concerned about that. The only downside I can see with the shorter tip is reduced climb, but I'll be running a 912UL (80HP) with a less than ideal length prop for climb, but I still have to believe it will out climb the average Aerovee.
I would probably have opted for the short tips from the beginning, but the project I bought has long tips. My plan was to fly it like this first, then try the shorter tip. Unfortunately, I noticed today that one of the tips is REALLY warped at the rear inboard edge, and it would definitely create some unwanted roll. Since I have to rework them, I'd plan to go to screws and maybe go to the short tips. I figure I can always go to the longer ones later if I feel I need more climb. We have a 6500 ft runway, so climb rate won't be an issue during the initial test flying.
Rusty
Rusty
Onex- Rotax 912 (135 hours and counting)
Fixed wing, gyroplane, A&P
