Re: Is the Onex really aerobatic capable?
Posted: Fri Jun 05, 2020 4:26 pm
Onex107 wrote:Onex107 wrote:Just keep in mind fellow aeronauts. The Onex fuel system is designed to only operate correctly in positive G's. Negative G's could cause you to run out of gas and vent liquid from the tank vent.
And I might add, the Onex tank vents out the bottom of the plane whereas the Sonex vents on the windshield and gasoline on the windshield results in cracks. That's why mine needs replacement.
I changed my Sonex to vent out the bottom of the cowl :-)
