RPM at TAS
RPM at TAS
Postby Thermalflyer » Sun Apr 26, 2020 12:06 pm
I am working on a project that requires some info for the ONEX with the 80 HP engine and standard gear.
Specifically: What RPM do you see at level flight and 60, 70 and 80 MPH TAS
Thermalflyer
Re: RPM at TAS
Postby XenosN42 » Wed May 27, 2020 8:39 am
Thermalflyer wrote:I am working on a project that requires some info for the ONEX with the 80 HP engine and standard gear.
Hello unnamed poster,
I'm curious: what is the nature of your project?
Here is the data for my OneX
Seconds | TAS (MPH) | RPM
117 | 92 | 2,682
71 | 81 | 2,646
46 | 71 | 2,464
Density altitude = 3,400 ft
OAT = 70 (F)
Weight = ~ 870 lb
Wing span = 18'19"
Wing area = 78 sq feet
Engine = AeroVee 2.1, naturally aspirated
Propeller = Sensenich W54JV5L44G
Conventional gear
Let me know if I've left anything out.
-- Michael
OneX N169XE
XenosN42
Re: RPM at TAS
Postby Gordon » Thu May 28, 2020 10:13 am
Question about the question....?
Why would you want to fly at a sustained flight speed of 60, 70 and 80 mph?
The only time I fly at those speeds is on the climb out or on 'final'.
At no other time would I want to fly at those slow speeds...…..just saying.
Gordon......Hummel 2400.....Onex
Gordon
Re: RPM at TAS
Postby Thermalflyer » Fri May 29, 2020 11:02 am
I need to calculate horse power to convert to KW. I am considering an electric so knowing KW at a few points on the power curve I can calculate how long it would fly and at what speeds based on a battery of 22KWH.
Thermalflyer
Re: RPM at TAS
Postby bnvoss » Sat May 30, 2020 7:26 pm
I have a Sonex with a Jabiru 2200 (80 HP) with a 54/46 Tennessee Prop. I went up this morning to 5,000 DA and 25C. It was a bit bumpy but here are my numbers.
60 IAS -- 2240 RPM
70 IAS -- 2350 RPM
80 IAS -- 2400 RPM
Bob
bnvoss
Return to Onex
Users browsing this forum: No registered users and 19 guests
