Exhaust Trimming
Exhaust Trimming
Postby WesRagle » Fri Aug 09, 2019 6:26 pm
Hi Guys,
How much exhaust pipe should I leave hanging below the firewall? Don't want too much, but don't want hot foot either :-)
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Re: Exhaust Trimming
Postby mike.smith » Fri Aug 09, 2019 10:07 pm
I have very little in my Sonex. Lower photo:
http://www.mykitlog.com/users/display_l ... 051&row=67
I believe the theory is to have the exhaust in the negative pressure area of the cowl outlet, without being draggy in the slipstream.
No hot foot. Unless you cut off the exhaust above the bottom of the fuselage I don't think heat is an issue. Exhaust is being directed downward.
Postby WesRagle » Sat Aug 10, 2019 9:33 am
Thanks Mike,
Makes sense. I'll just leave about an inch hanging out.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
