Re: A couple of questions
Tue Aug 25, 2020 10:33 pm
by WesRagle
radfordc wrote:WesRagle wrote:Yeah, I remember. I was hoping someone would agree that the only one of the forces that would cause an instant yaw while flying level at 100 mph when power is pulled is the "spiraling slipstream" being taken away.
Wes
Yes, the spiral slipstream changes when you reduce power. But, torque also changes, as does P-factor, and gyroscopic procession. Which effect is the most dominant....probably slipstream and torque. P-factor isn't a major factor except at higher AoA and gyro procession is most noticeable when turning or pitching.
And torque would cause a roll, not a yaw. That leaves only the slip stream. That's what I'm thinking.
Wes
Wed Aug 26, 2020 12:30 am
by Outlaw6
Wes,
I missed the nature of your question and distinction in speeds.
Re: Why the Yaw
Fri Aug 28, 2020 2:42 pm
by WesRagle
HI Guys,
Thanks for the replies. Sorry for being terse but I only had a tablet and I'm not very good at tapping out text on those things.
What brought this to the forefront for me was trying to nail my landings. I was reducing power from a low cruise setting to idle to begin my descent and the yaw was very noticeable.
Anyway, like Jeff said, there are really only two solutions to my problem. Adjust thrust to the left or move the forward tip of the vertical right (and remove the trim tab). Adjusting the thrust line would probably be the best solution but I wouldn't want to try to fabricate a new mount. Messing with vertical isn't totally out of the question. It would be pretty easy to asses the rudder inputs necessary for straight flight by removing the tab and marking the rudder cable in straight and level cruise flight. I wonder how that information could be used to estimate how far to move the tip of the vertical? Just project the cord of the rudder to the tip of the vertical? Hmm....
I'll probably just live with it for now. I don't want to miss any of the Fall flying weather :-)
Wes
