A couple of questions
Re: A couple of questions
Postby WesRagle » Tue Aug 25, 2020 10:33 pm
radfordc wrote:
WesRagle wrote:Yeah, I remember. I was hoping someone would agree that the only one of the forces that would cause an instant yaw while flying level at 100 mph when power is pulled is the "spiraling slipstream" being taken away.
Wes
Yes, the spiral slipstream changes when you reduce power. But, torque also changes, as does P-factor, and gyroscopic procession. Which effect is the most dominant....probably slipstream and torque. P-factor isn't a major factor except at higher AoA and gyro procession is most noticeable when turning or pitching.
And torque would cause a roll, not a yaw. That leaves only the slip stream. That's what I'm thinking.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby Outlaw6 » Wed Aug 26, 2020 12:30 am
Wes,
I missed the nature of your question and distinction in speeds.
Waiex N176WS (Tri-Gear Aerovee Turbo)
Outlaw6
Re: Why the Yaw
Postby WesRagle » Fri Aug 28, 2020 2:42 pm
HI Guys,
Thanks for the replies. Sorry for being terse but I only had a tablet and I'm not very good at tapping out text on those things.
What brought this to the forefront for me was trying to nail my landings. I was reducing power from a low cruise setting to idle to begin my descent and the yaw was very noticeable.
Anyway, like Jeff said, there are really only two solutions to my problem. Adjust thrust to the left or move the forward tip of the vertical right (and remove the trim tab). Adjusting the thrust line would probably be the best solution but I wouldn't want to try to fabricate a new mount. Messing with vertical isn't totally out of the question. It would be pretty easy to asses the rudder inputs necessary for straight flight by removing the tab and marking the rudder cable in straight and level cruise flight. I wonder how that information could be used to estimate how far to move the tip of the vertical? Just project the cord of the rudder to the tip of the vertical? Hmm....
I'll probably just live with it for now. I don't want to miss any of the Fall flying weather :-)
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Return to Onex
Users browsing this forum: No registered users and 25 guests
